Old 08-15-2006, 01:29 AM   #1
injectors
i was wondering when buying injectors if they should be high or low resistance and if you think 550cc is ideal or if i should go with a different size, any help would be great. thanks
ps power goal at the moument is 550whp.
Old 08-16-2006, 09:11 PM   #2
hell no. 550cc's are too small bro. Go to the RC website. They have a flow rate and a calculator. For 550whp, I recommend a minimum of 880cc's. The biggest saturated injectors you'll find is a set of 750cc RC's. Precision makes 680cc's saturated. Anything above 750cc's for Hondas will be Peak and Hold.
Old 08-17-2006, 03:53 PM   #3
i never truely undertstood peak and hold. i got a broad idea of what it is. but can you explain?
Old 08-17-2006, 09:27 PM   #4
It's really too technical for me to even describe it. I will just create more confusion. Just remember that the P/H injectors are easier to pulse under high RPM..... I think I've read that somewhere on the RC site..... it doesnt really matter as long as you have the correct injector drivers. But if dig deeper on Honda-Tech, you will notice that more people uses P/H due to higher volume output and less complex to control. All you need is a resistor box.
Old 08-17-2006, 09:42 PM   #5
hmmm i never knew you need the resistor box. i got a lot more reading to do.
Old 08-18-2006, 07:17 AM   #6
YES, all P/H injectors require resistor box, unless you are using an injector driver.
Old 08-18-2006, 02:20 PM   #7
whats the best way to go? esp when making the amount of power im trying to.
which is more reliable?
Old 08-18-2006, 04:36 PM   #8
peak and hold definately. They usually run cooler cause they peak open, and then lower the voltage to stay cool, but still hold the pintile open. As arnel said, you need a resistor box, or inline resistors to run them. There's a good comparison on the hondata website under the tech articles. Compares the heat build up of the two types.
Old 08-18-2006, 04:44 PM   #9
cool, so how much is one of these "boxes"
Old 08-18-2006, 05:07 PM   #10
a resistor box? Just get one out of an older honda. Honda used to use peak and hold injectors. I think it was on their OBD0 cars. It looks like a wird can of altoids with some wires sticking out of it. Some people also go to radioshack and wire resistors inline with the injector clips. Not sure exactly which ones you need though.
Old 08-19-2006, 08:20 PM   #11
Bro, I say get 880's or 1000's. OBD0 integras, preludes, civics/crxs for the resistor box. They are cheap.... I get them for free... junkyard donates it to me
Old 08-19-2006, 09:45 PM   #12
send me one.
Old 08-20-2006, 02:54 PM   #13
Originally Posted by IALuder
send me one.
No time right now. I havent been in the yards in a while.
Old 08-20-2006, 06:50 PM   #14
well then PHOOIE
