Old 04-03-2006, 11:47 PM   #1
tool...
do you need a special honda tool to adjust valve lash? Also where to get?
Old 04-03-2006, 11:49 PM   #2
if i remember correctly you just need a feeler gauge, box wrench, screwdriver, and a torque wrench.
Old 04-04-2006, 08:53 AM   #3
Snap on makes a special tool. It looks like a custom flat head screw driver enclosed in a 10mm box end tip. You still have to use a feeler gauge tho. I made my own. I'll take pics later......
Snap on:
http://buy1.snapon.com/catalog/item....re&dir=catalog
Old 04-04-2006, 10:29 AM   #4
it depends on the engine. D series you can do it with a box wrench, screw driver, and feeler gauges. However because of the valve cover design on the B series i'm pretty sure you need that special tool.
Old 04-04-2006, 05:06 PM   #5
good thing im using a D on the civic lx.
Old 04-05-2006, 01:26 AM   #6
just some offset wreches will to the job on b series ls
