Old 03-16-2006, 04:44 PM   #1
obd1 p75 - knock?
So I just realized that my ls block doesnt have a knock, being one of the original b18b's
The obd1 p75 doesnt check for knock does it? No biggie if it does, I'll just add a hole in the correct spot.
Old 03-16-2006, 10:41 PM   #2
sicones
sicones's Avatar
you gotta drill and tap??
Old 03-16-2006, 10:52 PM   #3
yep, theres a blank spot on the block where it should go
Old 03-16-2006, 11:57 PM   #4
Some peope use one of the alternator bracket bolt holes (retapped)..... I think that is a better idea. I just dont see myself drilling into my block...
Old 03-17-2006, 08:50 AM   #5
the alt bracket holes?
Old 03-17-2006, 10:02 PM   #6
yup........
Old 03-18-2006, 11:49 PM   #7
...interesting
Old 03-19-2006, 11:22 AM   #8
i know for sure mine does not have a knock sensor. maybe you could use the oil temp switch.
Old 03-19-2006, 09:49 PM   #9
Oil temp switch? You mean oil pressure sensor? What is he gonna do with the actual oil presseure sensor then? Knock sensor is just a tapped area on the block. It does not protrude the block at all. Pat, I'll se if I can get a picture of his set-up. I'm not even sure if he still has the motor.
Old 03-19-2006, 11:53 PM   #10
the oil temp swithc is 3in towards the tranny side on the block. on the later 94-01 models it's just a huge plug.
Old 03-20-2006, 08:56 PM   #11
hmmmm.... I've nevered paid attention to that.
Pat. my friend doesnt have the block with a modified knock sensor anymore, but I'm sure you can imagine how it would look like placing it on that spot where one of the alternator bracket bolt is.....
Old 03-20-2006, 09:38 PM   #12
yeah, I can figure it out alright
So we know for sure the p75 checks for knock?
Old 03-21-2006, 10:46 AM   #13
According to Hondata, NO....
http://www.hondata.com/ecus.html
Old 03-21-2006, 12:07 PM   #14
oh well then...pfff nevermind!
thanks arnel (forgot to even look there)
Old 03-24-2006, 07:02 PM   #15
No problem bro. Hurry up and finish the motor Pat!
