Old 03-01-2006, 12:07 AM   #1
overheating
So my car keeps overheating. My fan isnt working. hardwired it to see if that would keep it cool and it still doesnt. But if u get on it then u can watch it drop like a fat kid falling off a building. What should i check for? Help please.
Old 03-01-2006, 09:42 AM   #2
Dude... it's your headgasket!!!!! This is the culprit of all your porblems including your "not firing on all cylinders" thread. Bad headgasket means losing comrpession therefore no fire. Bad headgasket leads to oil leaks. Bad headgasket leads to coolant leaks. Bad headgasket leads to internal leak-by, once your motor reaches combustion phase, the internal leak-by will force hot gas to enter the jacket water side (the coolant side) which pretty much boils the shit out of your coolant..............
oh yeah, do not reuse those head studs/bolts. Get a new set. I would also get that head resurfaced.....
Old 03-01-2006, 05:44 PM   #3
but i fixed the damn thing. it still overheats. i got new head studs.
Old 03-01-2006, 07:18 PM   #4
Did you get the head resurfaced?
Old 03-02-2006, 12:36 AM   #5
no, why would that cuase overheating issuses?
Old 03-02-2006, 08:19 AM   #6
If your head is not flat, your headgasket will not seal properly even with aftermarket head studs.
Old 03-02-2006, 09:58 AM   #7
sicones
sicones's Avatar
you need to resuface the head every time? or just if its like been on there for a really long time....
Old 03-02-2006, 12:26 PM   #8
i always thought you could just use copper spray the first time it happened?
Old 06-30-2021, 05:14 AM   #9
hvxll2
Oh, my friend who is met similar problem.
hvxll2 is offline   Reply With Quote
Old 08-02-2021, 03:32 AM   #10
susu
Oh my god.
Better job. Better education. Better world. Explore more about teaching in Hangzhou.
susu is offline   Reply With Quote
Old 09-26-2021, 01:54 PM   #11
JustinBlack
I think overheating is a common problem. We need to fix it.
JustinBlack is offline   Reply With Quote
