Old 02-21-2006, 02:03 AM   #1
need a little help.
Alright so my car is shooting out white smoke after I go WOT. This was only after I got my exhaust valves replaced. Anyone know what it might be?
Old 02-21-2006, 11:14 AM   #2
Si-R CRX
It might be the rings if you have replaced the valves.
Old 02-21-2006, 11:36 AM   #3
prob. a head gasket... did they replace the HG when doing the valves?
Old 02-21-2006, 12:32 PM   #4
^good start on the HG. Are you overheating?
Old 02-21-2006, 01:51 PM   #5
overheating like you wouldnt believe.
Old 02-21-2006, 01:54 PM   #6
Si-R CRX
I would hope they would replace it.
Old 02-21-2006, 01:54 PM   #7
yea i doubt it. esp with the oil mess i have been getting recently too.
Old 02-21-2006, 02:10 PM   #8
yeah you're on the right track i think. However it could be the HG as well. Usually after a valve job (new valves, seats, whatever) it will cause the ening to produce better compression and vaccuum. So when the engine is on vaccuum and you have a weak headgasket, then it probably sucks in coolant.
Old 02-21-2006, 04:16 PM   #9
well GAD DAMN
Old 02-21-2006, 05:43 PM   #10
why did you post this question in this forum?
Old 02-21-2006, 05:54 PM   #11
If you are overheating, then your headgasket is FUCKED!.... which is also why you are smoking.....
Old 02-21-2006, 07:13 PM   #12
well time to figure why im overheating.
i figured why not post it here. more people will see it.
Old 02-21-2006, 07:42 PM   #13
sicones
sicones's Avatar
and leaking oil....
Old 02-21-2006, 07:54 PM   #14
yea i got an oil leak massive.check the lude forum.
Old 02-21-2006, 09:34 PM   #15
HG dude. no doubt
Old 02-22-2006, 08:59 AM   #16
sicones
sicones's Avatar
thats where I read it..
Old 02-22-2006, 04:18 PM   #17
i was just checking.
now to take time off work......fuckin car.
