Old 02-20-2006, 05:43 PM   #1
totallfou19
Fuel
ok so i fot the 92 civic hb for like 500 dollers and ne ways there is something wrong with the car. The car is fine for the first 3 min. Then the car dosnt resond with the gas. i have to floor it to get it to go it will slow down and one i floor it it like gets a kick in the but .... if ne one has a idea it would be great
totallfou19 is offline   Reply With Quote
Old 02-20-2006, 08:00 PM   #2
any check engine lights ?
Old 02-20-2006, 08:36 PM   #3
id say try changing the fuel filter and running a couple bottles of system cleaner over the next 2 fillups and see if that has any change on it
Old 02-20-2006, 09:43 PM   #4
rereading it sounds to me like the tps might be gone with the wind
Old 02-22-2006, 06:54 PM   #5
totallfou19
92 Civic
none are on
Old 02-22-2006, 10:19 PM   #6
i say it's the O2 sensor. Mine fouled out when my car was boosted, and when you start it it'd be fine, then it would warm up and start to bog out, and jump and misfire. My car was running so rich (because it was already rich and then the ECU adds more fuel when it doesn't know the A/F ratio) that i had misfires on all four cylinders and my check engine light even started to blink! Then i changed the sensor and it fixed it.
But also check other things too like your plugs, see how they look and what the gap is.
Old 02-22-2006, 10:19 PM   #7
Try unplugging the o2 sensor...
My car boggs out HARD then when you floor it it goes full blast... then once you let up on the gas again it boggs... you floor it it goes full blast... etc etc.
I re-wired my o2 sensor REALLY POORLY when I did my header... for me it's just a matter of soldering the connections and covering it well...
you MAY need a new O2 if the car runs fine with it unplugged... that or you could just run with it unplugged.
If it's not that then it could be a lot of things... TPS, Fuel Pump, Bad gas, Bad Fuel Filter, distributer... and on and on and on.
Old 03-04-2006, 11:50 AM   #8
2000Pimpinex
Super Moderator
2000Pimpinex's Avatar
First thing you should do is check for error codes. Could save you some time.
2008 Mustang GT
1998 Hatchback SOLD
1985 Ford Bronco XLT 5.8 351W
w/ 33X12.5X15
Old 03-04-2006, 09:54 PM   #9
Your car is probabaly pissed off at your horrible typing and won't run properly till you fix it.
Old 03-04-2006, 10:40 PM   #10
I cant understand the thread...... oh well. Next time, please read what you are posting before clicking the "submit" button.
