Old 12-29-2005, 03:07 PM   #1
Si-R CRX
B16a oil leak
I have a little oil leaking from under my distributor and before I go pulling everthing off right there I am wondering what it might be. Its not the cam seal that is in the front it is dry. The oil looks like it is coming from under or right behind the distributor and out onto the engine block. Its not alot but it stays a little wet. Where could it be coming from??
Old 12-30-2005, 05:03 AM   #2
I'm thinking the head gasket, but if it is coming from above the gasket, then it might be from the VTEC solenoid area since you already said "NOT the cam seal". Goodluck
