Old 12-11-2005, 10:46 PM   #1
my car doesnt warm up right....
I noticsed this the other day... My heat doesn't blow out HOT air until my car is above about 2-3,000 rpm... At idle speeds it blows out luke warm air.
Wondering if anyone else has had this problem? Thermostat reads normal, doesn't fluctuate....
Old 12-12-2005, 07:32 AM   #2
sicones
sicones's Avatar
how many miles are on the car, water pump??
Old 12-12-2005, 07:31 PM   #3
122K. would that cuase bad heating?
Old 12-12-2005, 08:51 PM   #4
sicones
sicones's Avatar
122k original water pump?? yea that would cause overheating and also the heat in your car, well it wont get there for you to feel it
Old 12-12-2005, 09:18 PM   #5
sounds to me like the water pump is going
Old 12-12-2005, 09:30 PM   #6
everything is oringal. water pump timing belt ect. i do believe. or changed a long time ago. like 55K.
Old 12-12-2005, 09:33 PM   #7
that is a long time on those belts and pump
even if that isnt the problem (which I also think it could be) change them anyway!
Old 12-12-2005, 10:03 PM   #8
i have been putting it off becuase im doing the hybrid so ill change them out then.
