Old 12-11-2005, 10:43 PM   #1
too much play in my suspension.....
It looks like I have some 'front to back' suspension play on the front driver side. My first thought was the bushings on the radius arms so I replaced both sides but it doesn't look like it cured the problem... any other ideas what it might be? Ball joint on the upper control arm maybe?
Old 01-09-2006, 03:33 PM   #2
well...this is about a month old....but...
which part exactly is giving you trouble? Like where is it loose, top or bottom?
Old 01-09-2006, 03:49 PM   #3
lower. im thinking ball joints.
Old 01-25-2006, 11:25 PM   #4
ewaugh
sounds diferent but front to back si generally a tie rod end
"Drive Carefully: 90% of all people are caused by accidents"
ewaugh is offline   Reply With Quote
