Old 12-04-2005, 03:42 PM   #1
ARP assembly lube
I just want to say how much I hate this crap.
For the longest time I have been having issues with the main bearings on the LS block. No matter what I tried, I couldnt figure out why I was getting resistance on turning the crank.
I had plastigauged it, and passed with .038mm on everything using ACL green standard bearings across the crank (even though I should have 2 browns in there). Plastigauge check rating is 40ft/lbs.
Finally, I just decided that I should get 2 thinner bearings (yellow code) to compensate for my problems...a $25 fix.
Before that, I decided to consult a builder on honda-tech.....
Turns out the ARP lube on my main bolts was causing them to tighten roughly 15ft/lbs tighter than the 56 spec that I should be using = 71ft/lbs. Holy hell...
Sure enough, drop the rating to 40 to compensate and the crank spins no issues what-so-ever. Hmm, exactly the same rating as the plastigauge test rating... No wonder it came out perfect there and gave me issues at 56!
Crap, that was frustrating.
I'll be cleaning this crap off and using straight oil as lube.
/rant
(Now that Ive done all that today, its time to get back to my paper that I shouldve written weeks ago)
Old 12-04-2005, 04:15 PM   #2
sicones
sicones's Avatar
wow 15ft/lbs would be that disastrous huh.....
Old 12-05-2005, 01:12 PM   #3
Glad you got it figured out Pat.
Old 12-05-2005, 03:38 PM   #4
so basically you're saying that the assembly lube was adding another 15 ft lbs to the spec and causing tight clearances?
Old 12-05-2005, 04:47 PM   #5
Yes, because the lube is so slippery it caused the torque to be higher before the wrench 'clicked' at the specific range - everything turned easier.
So when it did finally click, I had already surpassed the level desired
Old 12-15-2005, 06:07 PM   #6
Mr. Haan
do u have any pictures of the build/process? pics of the plastigauge? where can I get a plastigauge?
..Haan Mek-Anic..
Mr. Haan is offline   Reply With Quote
Old 12-15-2005, 06:28 PM   #7
Nah no pics...my mom stole my camera too
I got the plastigauge at autozone - they keep it behind the counter - it just comes in a paper sleeve with the measurements on it (blue, green, red)
Old 12-19-2005, 02:48 AM   #8
ExospeedRacing
Parked
IF you guys are building your own engines, I suggest investing in some Torco Engine Assembly Lube. PErsonally, we dont like using regular oil since it still doesnt provide as much lubrication as the assembly lube does. I'm not sure if ARP is similar to the Torco though. Never heard of Assy Lube making the torque go higher than it normally does.
Exospeed Racing Products / Exospeed Race Engines
www.exospeed.com
Custom Race engines and performance parts.
ExospeedRacing is offline   Reply With Quote
Old 12-21-2005, 04:12 PM   #9
Ive already removed all the arp and used regular oil - it really was the problem and from now on, only regular oil on my bolts
