Old 10-20-2005, 01:24 AM   #1
redneckwithaford
Parked
Dohc
I never looked into this but...
Will a DOHC head work on a D16A6 block or any D block for that mater.
Steve
redneckwithaford is offline   Reply With Quote
Old 10-20-2005, 01:43 AM   #2
not a b series dohc head, a D series dohc head can be made to fit a sohc block w/ extensive modification but its a nonvtec head and basically isn't worth the hassle at all. probably would lose power since swapping the head would drop the compression by a decent amount.
Old 10-20-2005, 01:49 PM   #3
actually az. swapping a D16 head on a D15 bottum makes the hybrid D15B Vtec block. which makes more power then the D16, but less then the ZC.
Old 10-20-2005, 02:07 PM   #4
huh? he's talking about swapping a dohc head onto a sohc block.
Old 10-20-2005, 04:07 PM   #5
....opps. i guess not.
Old 10-20-2005, 04:20 PM   #6
why not just buy a b18b engine out of a 94-95 integra ? cheaper, better power to start off with, and a bosst loving engine ??
Old 10-21-2005, 01:52 PM   #7
eh, I'd take the money that'd be spent on a swap and rebuild the d16a6.
Old 10-21-2005, 04:19 PM   #8
Around here, you can get a complete B18A minus the tranny for less $120
