Old 09-22-2005, 11:05 PM   #1
WTF ??? real big engine trouble
As all of you know i embarked on a pretty big project about a month ago and changed the timing belt and the bushings on my car. well today another surprise when i started running the car to bleed my brakes. After the car would warm up i would get a load of white smoke coming out of the exhaust. After i stoped the car and started it again after 2 hrs i noticed that there would be oil dripping down from between the header and the cat, so i decided to take the sparkplus off and inspect them, and see of there is anything in the engine. well # 1 sparkplug was full of oil, and the cylinder was also filled up with oil. tomorow i am taking the head off and see what the hell is going on. also after i noticed the oil i did a compression check and that cylinder read a whoping 250psi.
Old 09-22-2005, 11:26 PM   #2
drdingo21
drdingo21's Avatar
250psi!
Jesus christ on a cracker!
Old 09-26-2005, 12:02 AM   #3
MissJDM
MissJDM's Avatar
..Blown head gasket?
..Blown valve seals?
What was the conclusion!?
Old 09-26-2005, 07:16 AM   #4
well the head looks good so far. i need to clean it up and take the valves off.
Old 09-26-2005, 11:16 AM   #5
valve guide seals possibly
Old 09-26-2005, 03:08 PM   #6
well i think those wouldn't leak quarts of oil in the cylinder.
Old 09-27-2005, 08:41 PM   #7
Whtehnda93DXSdn
It has 4 Doors...
Whtehnda93DXSdn's Avatar
Are the rings shot?
Another good forum site:
Tuners Alliance
