Old 09-08-2005, 05:21 PM   #1
Whats your lists of mistakes when doing DIY's?
- stepped and slipped on a floor jack
- Automotive-Gooped my pants to my shirt
- dremelled a piece off my fingernail by accident...took off some skin behind the cuticle while I was at it
- don't accidentally touch a wire brush that's hooked up to an electric drill and is spinning
- put my center console together without plugging the antenna back into my deck...no radio
- burned myself on exhaust tip (never try to lower the exhaust yourself after having driven for an hour)
- cut myself on the inside of my fender (right under where the edge of the hood comes down)
- shocked myself hooking up 2AWG wire for amp power supply
- dropped a trunk lid on my head (took the springs off)
- stabbed myself with a voltage tester
Old 09-08-2005, 09:08 PM   #2
-slipping off the jack handle and hyperextending my thumb
-picking up a piece of metal that I was grinding on w/ bare hands
-cross-threading a mount bolt because I was tired, and didnt care
-wondering why a bolt wont go in, because Im turning it left, instead of right
-getting zapped by the battery because Im using a 10" extension, touching the opposite terminal
-too much threadlock on hood pin studs, making it impossible to remove the nuts
-wd40 is flammable
Old 09-08-2005, 09:24 PM   #3
-grinding without goggles
-doing electrical work without unplugging the battery
-using a 9/16 vice 14mm wrench/socket
-always snapping the rear lower control arm bolts
-spending all my money on I/H/E thinking it would make power... so I turboed later
-welding without gloves nor goggles
-welding while pants are soaked in oil... burnt the bottom of my pants
-using crescent wrench
-shorted out my O2 sensor cuz the wire was laying on the exhaust pipe, causing the insulation to melt and blew almost every fuse in my car
... theres more...
Old 09-08-2005, 10:08 PM   #4
Oh god yes
Old 09-08-2005, 11:16 PM   #5
lol at the crescent wrench. i think everyone has done that.
Old 09-09-2005, 02:23 AM   #6
CD5Passion
- blow fuses
- drop a nut or bolt down into the engine bay and have to dig it out.
- jack giving out -_- (that was scary as shit)
- broke three Craftsmen wrenchs
- forgetting about reverse threading
- put wrong bolt in wrong hole
- forget rotors get hot after driving and switching out brakes
Old 09-09-2005, 09:21 AM   #7
-shocking myself on the coil
-stabbing my oil filter with a screwdriver cause i couldnt find the wrench to pull it off
-forgetting to hook my alternator up after the swap(glad autozone gives free replacment batteries when its under warentee)
-forgetting to hook my fuel pump up after the swap the trying to figure out why it wont work for 3 days
-trying to fix shifter while driving
-not waiting till coolent is cold to drain it cause "they dont know what they are talking about"
and of course
- trying to use a crecent wrench
Old 09-09-2005, 04:15 PM   #8
Mischief
Mischief's Avatar
Originally Posted by GT40FIED
http://mensalmanac.com
