Old 08-26-2005, 01:41 PM   #1
Need cables...wtf
I bought a drive, was told it came w/ cables...it did not. I bitched, I yelled, they wont cooperate (I f*cking hate ebay anymore...)
SO...what cables do I need? IDE, I know...power, sure. If I roll into compusa, they'll have this, right?
This is all I got...a drive. I'll probably need a sheath and screws?
Old 08-26-2005, 03:32 PM   #2
all you need is the ide cable that's it. get a 40 pin 80 wire ribbon. they work a lot better on the ata 100/133 drives.
Old 08-26-2005, 04:18 PM   #3
will the mother board have the rest then?
Old 08-27-2005, 12:24 AM   #4
are you replacing any of the cd drives ?
here are the cables config from left to right as shown in your pic:
digital audio output, analog audio output (can use the old one from your motherboard), the jumper pins, the ide cable, and the power cable (the power source should have it)
Old 08-27-2005, 11:27 PM   #5
Im starting totally from scratch
Ive only bought the vid card, memory, this drive, and a stupid os
