Old 08-10-2005, 09:36 PM   #1
Grip72
Grip72's Avatar
bouncy idle at startup...wtf?!
right..my car was running perfectly and all of a sudden when i start it up now, it idles erracticly..it goes like 1500rpm, 700, 1500, 700....back and forth until it warms up a bit..anyone else have this problem? it gets really annoying and im' sick of people saying "why are you doing that?" or "what's wrong with your car?"
p.s. i already replaced the pcv valve!
Old 08-10-2005, 10:09 PM   #2
idle air control valve (IACV) on the back of the intake manifold
Remove it and try spraying it with carb cleaner to clean it out
Old 08-11-2005, 01:11 AM   #3
also check to make sure all the vaccum hoses are hooked up... thats what caused mine
Old 08-11-2005, 01:26 AM   #4
^curise controll vaccum line made mine jump from the exact same rpms. hmmm. sounds like a vaccum line.
Old 08-11-2005, 01:40 AM   #5
Grip72
Grip72's Avatar
there are SOOOO MANY FREAKIN VACUUM LINES ....oh god
that's gonna be harder then hell to find?!!? any suggestions for making it easier?!
Old 08-11-2005, 01:44 AM   #6
Mischief
Mischief's Avatar
dude you freak out alot, eh?
google for a diagram would be my guess
Originally Posted by GT40FIED
http://mensalmanac.com
Old 08-11-2005, 10:10 AM   #7
use the diagram under the hood
Old 08-11-2005, 09:24 PM   #8
Grip72
Grip72's Avatar
i dont' freak out alot..i just hate how my car runs perfect for like 2 weeks..then somethign comes up..then its good..then something else comes up..its very frustarating!
ok i took some pics and i also got a code 14 today which is Idle Air Control Valve
please help!
isn't the thing circled in green the idle air control valve?
and isn't the red electrical plug the connector for the IACV?
when i unplug the plug above with the car running, the idle drops and then when plugged back in, it rises back up.
isn't the thing circled in green the thermostat?
what is this thing circle in red? with the electrical connector?
[by the way the large opening on the right is my throttle body with the CAI removed]
ALL THE DIAGRAMS IN my Chilton manual book suck ass! any help is appreciated!
Old 08-13-2005, 11:24 AM   #9
sicones
sicones's Avatar
the thing circled in red is the TPS, throttle position sensor, you should never really have to mess with that.
Old 08-13-2005, 11:53 AM   #10
Yes, the green circled thing on the front of the intake mani is the iacv.
Like I said, its probably dirty and needs to be cleaned. Remove the electrical connector, throw on some electric grease; unblolt the iacv and clean the backside w/ carb cleaner. (While youre at it, shoot the carb cleaner into the throttle body, while the car is running, to clean that out too (you'll have to pull the throttle cable while doing this or it will stall out.
After you do all that, unplug the battery for a while to reset the ecu. If you still get the code after doing all that...I dont know what to say.
Cars are always trouble, if you ask me...but thats part of the fun.
Old 08-13-2005, 11:59 AM   #11
sicones
sicones's Avatar
well if he still throws the code after that I would just get a new iacv
Old 08-13-2005, 01:16 PM   #12
i know this may sound stupid but if sometimes if you start a cold car up with the AC on it will cause the idle to bounce, er at least that's how mine was before i yanked the AC
Old 08-13-2005, 02:35 PM   #13
Yeah, a new iacv would fix it, if cleaning doesnt...but theyre close to $200
Old 08-13-2005, 02:52 PM   #14
nope, that is just a fitting for the radiator hose. the thermostat is somewhere close to the intake manifold.
Old 08-13-2005, 03:36 PM   #15
^theres a sensor in there thought... what is it
Old 08-13-2005, 04:05 PM   #16
i don't know, on mine there are no sensors in that housing. all my 3 temp sensors are on the head under the dist.
