Old 08-09-2005, 10:16 PM   #1
how to tell...
some have suggested that my headgasket is bad, others think it might be more serious. without taking the engine apart, what tests can i have done to check and see if it were a head gasket problem or a rings/ valve seal problem?
Old 08-09-2005, 10:39 PM   #2
sicones
sicones's Avatar
compression test and connect a vacume guage, if you look in a helms its tells you how to do it and what to look for
Old 08-09-2005, 11:09 PM   #3
hmm, never thought to look in the book.
Old 08-09-2005, 11:59 PM   #4
leak down test. that is the best to do without having the engine apart
