Old 06-22-2005, 09:02 PM   #1
wheresmylicense
wheresmylicense's Avatar
when buying lips...
is it better to get abs plastic or poly urithane?
which is the actual JDM parts made of?
~DevT
Pictures of My Baby
Old 06-22-2005, 09:10 PM   #2
It depends on which lip.
ek sir lip is abs plastic
ek em1 lip is a urethan mix (like bumper)
Old 06-22-2005, 10:20 PM   #3
What are carbon fiber lips made of?
is one necessairly better than the other?
Old 06-23-2005, 02:35 AM   #4
RxGoaT13
RxGoaT13's Avatar
I've always heard the poly urethane lips are better.
RxGoaT13 is offline   Reply With Quote
Old 06-23-2005, 11:42 AM   #5
Basically, it comes down to how much you want to spend.
ABS is cheaper from the start and can be painted, but it looks fine, generally, just by itself - black plastic.
Urethane is more expensive up front and you almost always have to have it painted.
If the style of the lip is say, like mine:
Its probably safe to leave it unpainted.
If the lip is, however, like the ctr lip (98 spec is SO much better IMO):
It really should be painted...because otherwise, it'd look pretty shitty.
$100 now for abs and be done
$100 now for urethane, plus another $100 for paint = $200 (give or take a few $10s)
Old 06-23-2005, 03:06 PM   #6
wheresmylicense
so yours is an unpainted abs plastic type r lip, correct?
that's probably what i'll end up doing... save myself the hassle of painting.
~DevT
Pictures of My Baby
Old 06-23-2005, 04:08 PM   #7
Mine's an unpainted ek4 sir lip - oe honda. Cant find it anymore, and when you do, its nearly $200
The 99 spec ctr lip is similar and I think stefan has that one in abs
Old 06-23-2005, 10:09 PM   #8
what about the stock 99-00 Si (em1) lip?
Old 06-23-2005, 10:26 PM   #9
Old 06-23-2005, 11:35 PM   #10
yeah but i meant in reguards to the shape, compared to say, the CTR lip. Is it like a smaller version of it?
Old 06-24-2005, 06:13 AM   #11
wheresmylicense
so is abs plastic the same stuff as that textured plastic that the stock side skirts are made of?
~DevT
Pictures of My Baby
Old 06-24-2005, 02:39 PM   #12
Oh, yeah the em1 lip is like the 99-00 ctr style lip. It hangs from the bottom and has a bit of a jutting to the front, instead of just straight down.
Yep, the skirts are abs plastic. My lip is exactly the same material, texture, density, etc
