Old 06-20-2005, 12:52 PM   #1
Jayberg00
Jayberg00's Avatar
96 dx 97 gsr
i just got a 96 dx and was wondering if there is and way to put my gsr motor from my 95 civic in the 96 ek without getting a mount kit? can i use the can i use the ek bracket from the timing belt area on the gsr the tranny bracket from the single looks like it will work on the dohc i just need to know if the driver side bracket and mout from the 96 single can work on the dohc . thank
Old 06-20-2005, 04:55 PM   #2
the only other mounts that you'll need are the rear L (some call it a T) mount and driver side bracket, both from the 99-00 em1 si
Old 06-20-2005, 07:09 PM   #3
Leets
Leets's Avatar
that is correct... they should be pretty easy to come by and they're even relatively cheap from the stealership... the fun part, though, is the wiring.
Old 06-20-2005, 07:22 PM   #4
easily solved by using an ex harness
Old 06-20-2005, 10:37 PM   #5
I'm glad that you guys understood what he said. I couldnt decipher it. It went from a 96 DX to a 95 civic with a GSR motor to a 96 EK ... but the title shows a 97 GSR too...
Old 06-22-2005, 03:47 AM   #6
Jayberg00
Jayberg00's Avatar
ok thanks a lot guys ill be putting the motor in the car this weekend
