Old 06-05-2005, 11:53 PM   #1
Iat
Sooo my ls intake manifold doesnt have an IAT.
Give me a reason why I cant use the IAT from the y8, block/plug the IAT hole on the IM, and insert it on the intake arm again.
(If it was a threaded IAT, Id do that...but its a silly plug type)
Old 06-06-2005, 07:34 PM   #2
So let me get this straight, I know that the Y8 IAT sensor is a plug type which is held by a grommet on the intake pipe.
The LS IAT sensor should have 2 screws for mounting and is mounted directly on the IM.
It will work either/or. But bro, let me look around to see if I can get you one. I might have some laying around....
So are you saying if you can use the Y8 IAT sensor and grommet mount it onto the intake pipe?
Old 06-06-2005, 08:03 PM   #3
Right, exactly. (Dont ask why I thought the ls's was threaded last night)
I was planning on using the intake tubing from the y8's setup on the ls until I gather all the parts for boost.
IAT's are too much money from the dealer, for what they are...if I can do the swap I'll save myself the trouble.
Plus, Im not sure if the connector for the ls's and y8's will be the same.
If you have one sitting around, cool. If not, no biggie. I can make a little plate and block it off
Old 06-07-2005, 12:47 PM   #4
Bro, the clip should be the same. I dont remember replacing it. I just had to extend the wire.
Pdiggs, you better do the swap yourself man! I will kick you if you dont... ha ha.... There is nuthin' to it... I'll be at your dispose online and/or call my cell 757-575-8069.
Old 06-13-2005, 03:16 AM   #5
MissJDM
MissJDM's Avatar
Do you know how many weirdo guests we get on this forum? Sweeet, we all have yo number now!
Old 06-13-2005, 06:27 AM   #6
It's okay Lyna. You can call me anytime too........
Old 06-13-2005, 03:41 PM   #7
Oh Im definately doing it myself.
Even if I didnt have a single clue, Id be dumb enough to try.
I figure, though, if I can replace tranny bearing, I can swap an engine easy.
Old 06-13-2005, 04:15 PM   #8
that's what I'm talking about
