Old 05-11-2005, 04:22 PM   #1
P54 a/c bracket stuff
I know I need the p54 or the crv a/c bracket, and I know that my tension wheel and that for the Bseries are the same.
I just want to confirm that I need a couple things:
20 - Bolt 90054-P30-000
17 - Collar 38944-P2T-000
21 - Bolt 90086-PR3-000
15 - Bracket (This is different for del sol, em1, dc...go with em1? Matter?)
Old 05-11-2005, 04:25 PM   #2
hmm i have no clue but if you give me the year and the model of the car your engine came out of i can check it for you with the dealership. also i can get them for you
Old 05-11-2005, 04:31 PM   #3
Well the y8 a/c pulley crap is slide type, where this is some little arm thingy (part 15^). If I were using a B compressor Id just get em1 parts, but I gotta mix-n-match since Im using the D compressor on the b18b
Old 05-11-2005, 06:07 PM   #4
All B-series should be the same. I'm using an A/C assembly from a 97' Teg GSR. This includes: brackets (torque mount), pulley, pulley bracket, A/C. However, I had to get a CRV A/C belt since the crank pulley I was using is still stock CRV.....
Old 05-11-2005, 10:40 PM   #5
sicones
sicones's Avatar
I wanna do the same thing use my y8 compressor on the b18, not to change subject but is the power steering the same anyone know???
Old 05-11-2005, 11:04 PM   #6
I dont think that's gonna work pdiggs. I tried it. The D compressor will not bolt to the B mount/bracket. I already tried....
Sicones, The power steering is different too. You must use a B-series pump. The bolt pattern is not the same on either the A/C or the PS. You can still use your existing reservoir. You will also have to either replace the hose that goes to the ram or modify the D fitting. I cut my D fitting and used a B fitting. I welded that fucker and it works great!
Old 05-12-2005, 06:41 AM   #7
It does work w/ the p54 a/c bracket (off a del sol vtec). Ive heard rumors that the crv bracket also works, but Ive never gotten any sort of confirmation.
Old 05-12-2005, 05:48 PM   #8
sicones
sicones's Avatar
on the ps, where the hose turns to metal and the two bolts go though, can you just use the b metal part and one of those hose to hose connecting things with the teeth and hose clamps
