Old 04-28-2005, 02:37 PM   #1
JspecCrxSiR
JspecCrxSiR's Avatar
i need mad help
well i have a 94 ls integra and i have currently added the holley fuel rail 210cc injectors venom intake manifold intake headers and exhaust but my car is overheating i put a new water pump thermostat checked the fans and they do work and the radiator was checked as well i can drive th car but when i get to my destination u can hear the making bubbles in the resevoir like if the water was boiling please help im running out of ideas
thanks
JspecCrxSiR is offline   Reply With Quote
Old 04-28-2005, 02:44 PM   #2
does the temp gauge register the overheating ? sometimes the sensors go out and they do not trip the CEL. also another thing could be a blown head gasket or a big ass air buble in the water pump. have the compression checked, or a leakdown test done. if that does fine just drain and fill the coolant system again. also check to see if your timing is not out of whack since you did all that mad work on the timing belt.
Old 04-28-2005, 07:14 PM   #3
hmmm why did you go from a stock 240cc to a 210cc? .... or do you mean 310cc?
Old 04-28-2005, 08:59 PM   #4
JspecCrxSiR
yeah it was 310cc well the timming is good the needle doesnt go up only when it has no water it like the coolant eveporates and stuff blown head gasket cant be cause i had barely put a copper head gasket so i can boosted but i dont want to yet cause of that problem and the compression is still good
how do i dod the leak down test i do all the mechanical work on my car cause we have shitty machanics here in El paso TX and over charge and dont know shit about hondas and acuras
and i keep putting water and coolant like every 3 days and stuff i think i might be the water pump messed up since i have warranty i can exchange it again but i dont know the car doesnt smoke at all or any vapor from the exhaust please help
Old 04-28-2005, 09:33 PM   #5
that copper head gasket is your problem. that is because you need to o-ring everyting on it in order to prevent leaks. i heard horror stories about the copper head gaskets.
Old 04-28-2005, 09:44 PM   #6
JspecCrxSiR
yeah i did all of that as well i know i have no leaks and the was doing way before i got it as well and it had the stock head gasket and its still doing the same thing i barely have it for a 2 months its frustrating thanks
Old 04-28-2005, 09:50 PM   #7
Before you do a leak down test, get a clear bottle and drain some fluid from your radiator and your oil pan. Inspect both fluids for sign of contamination........
Old 04-28-2005, 10:49 PM   #8
JspecCrxSiR
ok i did the leak down test and the oil is still like knew cause i run on royal purple and the coolant is still orange with no contamination im runin out of ideas
Old 04-28-2005, 10:58 PM   #9
bad thermostat maybe ? or faulty rad cap ?
Old 04-28-2005, 11:10 PM   #10
JspecCrxSiR
ok it has a brand new radio cap and thremo stat as well
