Old 04-07-2005, 03:50 AM   #1
JudoAnt
Squeaky front end
on the 94 accord i have noticed a squeak when i get in and out of the car, when i push down on the hood and take turns. I have replaced lower ball joints, but the left has a tear in it again and greese has been leaking for months. the upper control arm joint boots are also torn and dry. i also hear squeaking when to turn the wheel back and forth.
could ball joints and upper control arm joints be causing all this noise? do the shocks and struts need to be replaced too? How about springs?
shocks/struts have never been done. i''ve had the car 80k of 170k.
Old 04-07-2005, 10:47 AM   #2
my guess is that the bushings are already torn.
Old 04-09-2005, 09:31 AM   #3
CD5Passion
my rear end squeaks...but thats only cause my springs dislodged themselves and aren't sitting correctly...wtf
Old 04-26-2005, 04:35 AM   #4
JudoAnt
I have bought new upper control arms and lower ball joints.
I am wondering if in the replacement process if i should replace anything else while its torn down? Are there bushings involved in these assembly's or are bushings just w/ suspension?
Does anyone have a diagram of an accord front end?
Old 04-26-2005, 01:52 PM   #5
ShEaNy
ShEaNy's Avatar
yea i got a squeek in my front right wheel well...i tihnk its the bushings..or my coil over...not sure though..
