Old 03-24-2005, 11:42 PM   #1
Damn it!
So the tranny fix is a total bust.
I replaced the standard clutch parts (clutch, pressure plate, throwout bearing, pilot bearing, and had the flywheel resurfaced) and replaced the input shaft bearing, which I was told would be the cause of my "bad bearing sound".
I took it out for a drive today (first time since fixed) and the sound is still there....but worse!
I installed everyhing correctly, and torqued things in the right order/way.
Does anyone have any suggestions?
I swear I will go totally berserk if its the countershaft bearing....
I will sadly be taking it to a shop otherwise....
