Old 03-20-2005, 11:29 AM   #1
Jayberg00
Jayberg00's Avatar
Jdm B16
i have a 90 civic Si with the 90 EF JDM motor i have everything swaped int with and no Check engine light the 4 wires are not hoked up yet knock tec activation teck ressure and 02 sensor still no light, the problem is that its idling ant 2grand even when it is warmed up any had this problem b4
Old 03-20-2005, 01:37 PM   #2
sicones
sicones's Avatar
maybe you should connect those sensors
Old 03-20-2005, 02:01 PM   #3
youve probably got a vacuum leak
Old 03-20-2005, 06:07 PM   #4
^check all vacuum connections. i cant understand what you are saying. Please put periods and spell check. Make sure your O2 sensor is hooked up. Oxygen is an input to fuel map....
Old 03-21-2005, 01:06 PM   #5
-.NsaNiTi.-
Id put my money on the O2 sensor as well, Ive run into this problem before. And please.. learn how to type. We dont all have a Rosetta stone to decipher that gibberish. lol.
-.NsaNiTi.- is offline   Reply With Quote
Old 03-23-2005, 01:46 AM   #6
but wuttz werong wit mah typin skillz y0
Seriously though. Check all Vaccume lines. I know that was my problem at one point.
Old 03-23-2005, 02:35 AM   #7
MissJDM
MissJDM's Avatar
I think the links are hooked up wrong...so with all of us coming up with the same conclusion, you should give it a shot and then let us know how it goes.
awlrite?
