Old 02-06-2005, 08:36 AM   #1
when i spray......
the kit that i have is the nitrex wet kit.i have been over and over this system with the manual and i have it set up as well as it gets.
i am haveing problems with the motor acting like it is choaking or caughs after the inital hit and let out of it.i was useing 35 shot or both of the smallest jets.it seems to get worse if i try to use a larger fuel jet.i am useing the b&m fuel preshure regulator at the recomended 38/42 psi.it seems to me that i am geting too mutch fuel.i have turned off the nitrous and blead off the nitrous then tried just the fuel,it did the same choaking etc.i know the nitrous it working when i use it because i can here the spraying noise.i have talked to some of the guys at the track in the v8's that use nitrous and they are telling me that they are useing a stand aloan fuel pump system at 8 to 12 psi.
So if fuel preshure is the problem how are you guys regulateing your efi system?the nitrous kit is for a efi system.
Old 02-06-2005, 12:05 PM   #2
are you just copy and pasting shit or what?
Old 02-06-2005, 09:22 PM   #3
this one yes.
