Old 02-06-2005, 08:24 AM   #1
fuel pump
I plan on using the AEM fuel pressure regulator and fuel rail. Do I need to upgrade the stock fuel pump? I have heard horror stories of people upgrading their pump. Also, I see that internal and external pumps are available ( I was looking on horsepowerfreaks) for the lude. Which is better? If you do recommend the upgrade, which brand?
Old 02-07-2005, 12:07 AM   #2
MissJDM
MissJDM's Avatar
I always figured that it'd be okay..only needed if you were going to the "extreme."
Old 02-10-2005, 05:15 PM   #3
C's 94 InTeGrA
C's 94 InTeGrA's Avatar
If your running more than 8 pounds of boost its a must. But if you want go ahead and upgrade its not going to hurt you
Old 02-11-2005, 07:31 PM   #4
I think it's not a bad idea. I just like the thought of having the volume of fuel ready if needed. Just remember that your FPR will still regulate the amount of fuel to the injectors regardless of what size fuel pump you have. It's the readiness of the volume to be "there" that puts my mind at ease.....
Old 02-11-2005, 07:51 PM   #5
whats the point of upgrading the fuel rail?
why are you upgrading the regulator?
Old 02-18-2005, 07:22 AM   #6
ill be boosting with n2o.
Old 02-18-2005, 11:39 PM   #7
and?
get a nx wet kit and you don't need any upgraded fuel components.
Old 02-19-2005, 09:40 AM   #8
but you do when boosting over 10lbs.
Old 02-19-2005, 12:00 PM   #9
oh. well you still don't need an upgraded fuel rail or a fuel regulator if you get a good engine management. don't you have to get your engine rebuilt first?
