Old 12-27-2004, 07:31 AM   #1
motor problem
just got a block delivered and i found some scratches on the piston walls, there not to deep, but enough to feel with you finger. what do you recommend i do?
its a D15 non vtec civic block. if your wondering me and a friend of mine want to build a d15B Vtec block. using the head of a D16y8.
but the block came with low miles but with scratches. so i dont know what could of cuase that.
Old 01-16-2005, 09:42 PM   #2
i suggest trying to rehone that bitch. see what local shops say about it
Old 01-17-2005, 03:00 AM   #3
The safest way is to get it rehoned but how far do you want to build this motor? New pistons? If u plan to get new pistons of an aftermarket version, then just wait. Have a shop look at the walls. That may determine what size piston diameter you may need.....
Old 01-17-2005, 08:03 AM   #4
not fully build. we want to make it pretty much like a stock D15b. ill see what the shops have to say. right now were fixing the d16y8 head. we took it off a car that was boosting unsafely. bent the valves. we got the head for 55$s.
