Old 12-27-2004, 07:24 AM   #1
ABS Code
Yes my friend Kohns 94 Accord which I just discovered, has an ABS CODE of 5 4. ( rear wheel lock - R) Can someone please tell me what this means, and what i need to do to fix it?
Is it really important to have fixed right away, or will just the abs feature of my car not work?
Old 12-27-2004, 08:43 AM   #2
well i think one of the sensors took a dump. i don't think that requires immediate attention, but the wheel will lock when slamming on the brakes
Old 12-27-2004, 11:30 AM   #3
but ABS will not work with out the sensor right?
Old 12-27-2004, 11:40 AM   #4
it won't work for that wheel only. the other 3 will work
Old 12-27-2004, 11:41 AM   #5
that sounds rather bad. how much is a new sensor?
Old 12-27-2004, 12:09 PM   #6
i need more details about the car, like tranny, trim and number of doors
Old 12-27-2004, 03:11 PM   #7
95 ex 5spd 2dr.
Old 01-17-2005, 11:00 PM   #8
ifeldwn02
3rd Gear
if the abs system has a problem it wont work at all so that it want mess up any other section of it. almost the same as if your vtec system were to have a problem it will keep your motor from engaging vtec by lowing your rev limiter so that none of the componets will be damaged
