Old 12-27-2004, 07:05 AM   #1
wastegate problems agian.
Is there any way to see if the wg is opening or not? For some reason im not getting any boost and i trouble shoot it to being the wastegate. Is there anyway to see if the spring is working properly?
im working on my friends car. its a turboed laser.
Old 12-27-2004, 09:43 PM   #2
in other words, you've checked all the piping for any signs of leakage right? To check the wastegate, move the rod side to side. The only way to acurately check it is to take the whole turbo assembly out and hook up a pressure gauge with pressure source to the diaphragm. Once you do that then observe the gate open as you apply pressure on the diaphragm
Old 12-28-2004, 07:40 AM   #3
thanks! yes we check all lines and pipes.
Old 12-28-2004, 10:55 AM   #4
...or it could be that the gate itself is completely worn out.....
Old 12-28-2004, 04:32 PM   #5
thats worse case scenerio.:o
Old 12-28-2004, 08:59 PM   #6
yep
Old 01-15-2005, 10:20 AM   #7
well, the fawking thing blew. we replaced it with another one out of a -j-yard.......IT DOESNT WORK EITHER!!!!
Old 01-15-2005, 11:02 PM   #8
time to get an external bro...
Old 01-16-2005, 03:20 AM   #9
how hard to switch over? do i need to replace anything else?
i might take the two bad ones apart and see if i cant fix one with the other.
Old 01-16-2005, 08:22 AM   #10
it'll take a few hours of fabrication. You will have to find a way to keep the internal gate shut or open if you place the external gate somewhere on the manifold runner/collector
Old 01-16-2005, 08:53 AM   #11
gawd damn. at least its not my car or money.
maybe hell just buy a brand new one.
