Old 12-20-2004, 07:36 PM   #1
Fatal070
Fatal070's Avatar
Hmm A bit odd
So I downloaded some software with a crack... the problem is I have no local settings/ Temp folder I'm stumped and could use a bit of help thanks
Old 12-20-2004, 07:45 PM   #2
uhhh, what os are you using ? i think i need more detail to try and help you
Old 12-20-2004, 08:02 PM   #3
Fatal070
Fatal070's Avatar
It's just odd I can't find my local settings or temp folder... is there any reasson I would not have either of these folders?
Old 12-20-2004, 08:04 PM   #4
could be hidden
Old 12-20-2004, 08:47 PM   #5
Fatal070
Fatal070's Avatar
yeah but if it was hidden I should still be able to find the folders, I download Adobe Premeir and it came with a crack and the only way to make it work is to replace the original file with the crack... but I can't find the damn folder I need!!!!! ERRRR....
Old 12-20-2004, 09:06 PM   #6
C:\Documents and Settings\Administrator\Local Settings\Temp in case you are using xp
and yeah, local settings is a system folder and most likely is hiodden from view. go to folder options ans select show hidden and system files
Old 12-20-2004, 09:10 PM   #7
Mischief
Mischief's Avatar
edit: yes this is what I do in my free time.. god I'm so bored.
Originally Posted by GT40FIED
http://mensalmanac.com
Old 12-20-2004, 09:14 PM   #8
those 2 im's are hot chicks ? now i have their user names
Old 12-20-2004, 09:18 PM   #9
drdingo21
drdingo21's Avatar
If its a hidden folder and you have display hidden files turned off. Search will not find it.
And you can change where the files are extracted to. Try changing it to C:\
Stefan when the shit are you coiming down here?! Mikes here now.
Old 12-20-2004, 09:48 PM   #10
Fatal070
Fatal070's Avatar
thanks but I did search way to be a dick though
Old 12-20-2004, 09:50 PM   #11
Fatal070
Fatal070's Avatar
How do I display hidden files, where do I go exactly?
Old 12-20-2004, 10:39 PM   #12
drdingo21
drdingo21's Avatar
Double Click "My computer" then from the Menu Bar, select "Tools" then "Folder Options", select the sencond tab labled "View"
Then about half way down, there is "Show Hidden files and folders" put the bubble next to it, then apply and ok out of everything.
I think by far the easiest thing to do would be extract them to the desktop.
Old 12-20-2004, 10:39 PM   #13
Mischief
Mischief's Avatar
actually both of those IM's are me, using Dead AIM
Old 12-20-2004, 11:13 PM   #14
MissJDM
MissJDM's Avatar
This is where Darin steps in. =P
Old 12-21-2004, 03:55 AM   #15
Fatal070
Fatal070's Avatar
Thanks for the help, I really do appreciate it !
Old 12-21-2004, 07:16 AM   #16
CD5Passion
only out of confusing...getting off work at 11:30 getting 3hours of sleep and having to work from 8am-6pm.....I'm half asleep.....roads here I come:o
