Old 12-12-2004, 05:03 PM   #1
Civic_RedLine
3rd Gear
Civic_RedLine's Avatar
Changing 01-03 tail lights to 04 coupe tail lights
This mod is extremely easy to do. Dont think that all you need to buy is the 04 honda civic coupe lights in order to swap your 01-03 tail lights to 04. Before you do this mod, I suggest you do your research with Honda because they will tell you everything you need.
All I needed was the rear wiring harness and the sockets to fit the new wiring harness.
COST:
100$ per tail light
50$ wiring harness (REALLY HUGE)
4x$5 socket bulbs
After you get all that, unplug the harness in the car already, then plug the new harness. THATS IT!
All this is is common sense, there is no splicing required, it is all plug & play.
I suggest you look for the tail lights on ebay because honda will charge you 100-115 per light= to ebays 75$ for both lights.
I gaurantee you wont find the wire harness on ebay neither junkyards unless its a good one.
I would post a DIY, but this mod is extremely easy. Once your done installation the new 04 lights, it will look way better than the square reverse light model rather than the round one. Go check on ebay to see the 04 lights, you'll see how much better they look
Old 12-12-2004, 05:31 PM   #2
Civic_RedLine
3rd Gear
tail light pic
Old 12-12-2004, 05:32 PM   #3
Civic_RedLine
3rd Gear
pic
