Old 12-04-2004, 12:34 PM   #1
too early to tell ?
well i noticed a big lack of power in my integra lately and i decided to do a compression check on it. here are the readings:
Cyl. #1 120psi
Cyl. #2 150psi
Cyl. #3 150psi
Cyl. #4 180psi
Background: I noticed the timing belt is loose as hell when i did the vlave lash and i could not align the signs on the cam gear for the life of me. anyway i went out and did it. Changed the plugs at the same time i did the valve lash adjustament. all of them had a tanish color on them and very slight carbon build up. Today the #1 cylinder plug had a lot of carbon buildup ( improperly tuned engine) and a tanish color on it too. So everything happened between the valve lash adjustament and now (about 2 months).
Possible Causes:
-The timing belt fucked up everything and needs to be tightened then redo the valve lash and see what happens.
-Bad head gasket (notice how identical #2 and #3 cylinders are in readings).
-Bad motor. get rid of it and pimp out the accord again which reads 190psi across all the 4 cylinders.
Ideas and condolences please post here
