Old 10-28-2004, 10:56 PM   #1
intermitent wipers
for some reason when i turn on my intermitent wipers they keep on going continously if my headlights are turned off, and if the headlights aren't on the intermitent wipers won't work at all. the low and high speed work fine no matter if the headlights are on or off. also when i use the sprayer the wipers won't turn on automatically, i will have to manually put them on. anyone have any idea ?
Old 10-29-2004, 12:24 AM   #2
ShEaNy
ShEaNy's Avatar
no idea but I have the same problem......i have to hold the damn thing down to clean the windows...happened ever since my car got broken into..when they fudged up the column...prolly wiring inside the steering column or a fuse or something...
Old 10-29-2004, 11:18 AM   #3
the fuses are ok. might be a wire inside the column or a relay.
Old 10-29-2004, 11:22 AM   #4
AkimboStylee
AkimboStylee's Avatar
same thing happens to my civic. its a bad relay
Old 11-01-2004, 10:37 PM   #5
ok and where would that be located ?
Old 11-02-2004, 03:15 PM   #6
ShEaNy
ShEaNy's Avatar
its gota be in the column man have u taken it apart? the piece should just come apart (behind steering wheel)...
