Old 10-21-2004, 05:29 PM   #1
B16DoHcCrx033003
B16DoHcCrx033003's Avatar
hondata
alright i am turboing my LS crx... but a few issues... i dunno to go with FMU and missing link since i am only boosting 8-9 pounds. or go with a hondata system. i am on a tight budget and i need to know how much a full hondata system would be. the 200 one i think? i dont know much about it. or just stick with the FMU and missing link...thanks guys
Old 10-21-2004, 06:08 PM   #2
fmu's suck...period
You'd be better off with the afc hack if you dont want to spend the cash on hondata.
If youre capable, you could try uberdata, which is free.
Old 10-21-2004, 06:55 PM   #3
i thnk you could go with ghettodyne too. uber data is also very good for auto ecus because it does not remove the shift points.
Old 10-21-2004, 09:01 PM   #4
B16DoHcCrx033003
that means i would have to go with an older ECU right now i have a P75, so might as well just stick with it. i think hondata might be an option right now. i just need to know how much it is and what i will need and everything if anyone got any information that would be great... thanks guys
Old 10-21-2004, 09:15 PM   #5
hondata with boost is around 475 for the chip alone. then you would need it installed and tuned
Old 10-21-2004, 09:18 PM   #6
B16DoHcCrx033003
i already got an installer and tuner.... he said just to get a hondata s100 with boost which is $445 and a 3 bar map. and injectors is all i need
Old 10-21-2004, 09:29 PM   #7
i was talking about the s200b
Old 10-21-2004, 09:30 PM   #8
B16DoHcCrx033003
but would i really need that... i think the s100 is good enough. i am not planning on running more then 9 boost really... and i cant drop like $1k onto a managment system? any other info about hondata tho?
Old 10-30-2004, 08:58 PM   #9
If you have the time to learn about it, uberdata really is free hondata.
http://home.mn.rr.com/keebler65/honda/uberdata.html
http://www.ecimulti.org/uberdata/index.html
Ive decided that I need to learn it better so I wont have to shell out the bling for hondata.
