Old 10-20-2004, 05:16 PM   #1
chefmaster21
screeching belt
please help i have a screeching belt, when i start my car in the morning when it is cold. I just had all my belts changed about 20,000 miles ago. When i had the belts changed then it wasn't cold so i coulnd't tell if it was doing it or not. Anyway anyone have a clue what belt it is ??
chefmaster21 is offline   Reply With Quote
Old 10-20-2004, 05:29 PM   #2
racerface562
try to recheck and tighten all belts. I had this probem when i changed alternators, I had to tighten the belt that was connected to the alternator.
racerface562 is offline   Reply With Quote
Old 10-20-2004, 06:52 PM   #3
MissJDM
MissJDM's Avatar
so you changed your ac/power steering/alternator belts, but not the timing belt?
Old 10-20-2004, 07:09 PM   #4
chefmaster21
yes, of course i changed the timing belt, and water pump too.
Old 10-21-2004, 10:10 AM   #5
yeah check the tensions on all the belts, if that doesnt fix it, I think autoparts stores sell stuff that quites belts down. never used it, but i've heard of it.
Old 10-21-2004, 11:30 AM   #6
^yup. some sorta grease/lube.
but i got a A/C belt that does it only when the air ison. turn all that off and start it. if so id be the ac belt.
Old 10-23-2004, 08:16 PM   #7
chefmaster21
i would assume it's not the a/c belt. It does screech when its on, but it also screeches when it isn't on. What other belt could it be? I guess i should just adjust all of them. Is it easy to adjust the tension on the belts? Or should I just take my car some where to have it done. My ex used to do all the work on my car. any suggestions?
Old 10-25-2004, 10:22 AM   #8
i wouldn't rule out the a/c belt at all. you say it makes the noise worse when it is on? I would think that proves that that is the problem. Check that tension first.
