Old 10-06-2004, 07:14 PM   #1
product question
check this out, saw it in an ad in honda tuning....
http://www.innovatemotorsports.com/
hmm wideband a/f unit? and it's at a reasonable price.. and has many other features.
Here's my latest question, in theory i could get some dyno time at this place i know ($100/hr) get the wideband monitor and then just tune with the apexi afc and other components. Any thoughts?
Old 10-06-2004, 07:36 PM   #2
That is not a bad wideband system. I prefer AEM or PLX (hardwired) tho but as long as it works.....
Theoretically that is right. Get your A/F target correct and your system will be considered tuned. However it's efficiency is still a question since the tuning device is still what's controlling the signals and fuel map. The more adjustability, the better. For example, the tuning/adjustability on an AFC is nowhere near what AEM-EMS can do. So it is more likely to achieve higher horsepower on a more tunable system.
My advice is just to make sure that your tuner is skilled on whatever tuning device you are getting ready to use....
Old 10-06-2004, 08:56 PM   #3
apexi afc= 300
aem ems= 1300 ish
wideband monitor=350ish
aem wideband= 600ish
hey, notice a pattern? i'm trying to save money! lol
i just need to find some better shops, i just wish there was more to work with...
Old 10-06-2004, 09:18 PM   #4
I hear you..... It was just a comparison of its abilities.. that's all. I am aware of the prices, trust me....
Old 10-06-2004, 09:55 PM   #5
oh i know.
i really wish i had like 10g's. Then it'd be a built b20 with boost through the AEM EMS and a bajillion other things. someday....
Old 10-07-2004, 07:34 PM   #6
Sivik
b20... cylinder walls are too thin... if i had money, i'd get rid of my civic and get some AWD power!
Turbo'd 98 Honda Civic EX
My Car
My Car is for sale
Old 10-07-2004, 10:22 PM   #7
mmm true, my friends WRX does give me a hard-on everytime i drive it.
Old 10-10-2004, 05:29 PM   #8
SO anyway, i have to go the AFC route. Hondata just isn't an option right now (maybe come spring). So for now i'm going to get a vafc, missing link, and dsm injectors (and resistor box) that way i can at least get it up and running conservativley and come spring i'll go hondata...
Old 10-10-2004, 11:45 PM   #9
Sivik
no need to run missing link with AFC hack. goto thermal's website for setup instructions and settings. helped me.
i still say go for the hondata, so much better and safer for your motor. just gotta get it tuned right.
My Car
My Car is for sale
Old 10-11-2004, 11:54 AM   #10
oh true i forgot about the afc hack
i can't go hondata, i don't have the money and the only place that tunes it is expensive and far away. So it'll have to wait until spring.
Old 10-12-2004, 11:10 PM   #11
P28 ECU= $75
ECU socketing= $75
Hondata S100b= $385
440cc injectors= $225
Hondata base map= $50
= $810
Apexi VAFC= $350
RC 440 cc injectors= $225 or DSM 450cc injectors= $75
Resistor box= $10
=$435 ($585 if RC 440 is chosen)
The price difference is pretty big. However you can get everything you need to run a Hondata system less than what I listed from H-T. I see it all the time under classifieds. I've seen it as low as $600 with everything.... used
But as I mentioned before, you will gain more with Hondata. Also, OBD2 tends to trip a CEL code 13 (barometric pressure) under an AFC "hack". It doesnt affect the performance of the car, however it's just annoying to be seeing that yellow light all the time.....
If you decide to do the AFC hack, I say get at least the right injectors vice a DSM 450cc. Get the RC 440 or 550 cc saturated injectors. DSM injectors doesnt act well on "hot start".... when the weather is hot or with the engine being hot. Sometimes it takes me a couple of clicks and hold the starter engaged for a few seconds to get the car going. Since you will be going Hondata later on anyway, you might as well get the right injectors. The Hondata website doesnt recommend DSM 450cc (peak & hold) anyway. RC, Lucas, Precission, or Seimen injectors will be okay.
Old 10-13-2004, 03:05 PM   #12
well if i spend the extra money with the RC injectors then they're just plug and play since they're the same resistance correct, hence i wouldn't need to wire in a resistor box. I guess i'd better go that way, not to mention i know i'd have new injectors and they'd work better.
Old 11-07-2004, 11:13 AM   #13
BlackEJ
BlackEJ's Avatar
For the Rc 440s you do not need a resistor box.
and btw like arnel said:
Hondata P28 Chipped ECU (OBD2B) = $375
Hondata S200b= $445
440cc injectors= $276
= $1146
This whole set up is teh way to go, thats what I am running
Yo check out this doods
http://www.wiredspeed.com/
Joo will bow down to Teh mastah
BlackEJ is offline   Reply With Quote
Old 11-07-2004, 12:41 PM   #14
i could only find one place to tune the hondata, and they wanted 700, so i scratched that idea.
I'm running an apexi vafc and i have a set of tuner toys 450cc High impedance injectors. So i'll be running the map sensor hack once i get everything installed.
Old 11-07-2004, 07:27 PM   #15
BlackEJ
BlackEJ's Avatar
Goddamn 700 WTF are they thinking.
Were they trying to charge for Install, base map, tuning and dyno time all together or what man?
700 is fucking outrageus,
shit I paid 250 for all of my ^ ^ ^ ^ ^ ^ ^ ^ ^
Old 11-08-2004, 03:48 PM   #16
my thoughts exactly. They claimed it was a flat rate and if forgot what it all included but i'm pretty sure that was without the hondata system which was rediculous.
