Old 10-06-2004, 04:45 PM   #1
Did you know
Did you know that integra front calipers bolt directly up to 92-00 civic ex and 99-00 si? (You will need 15" wheels...Im lucky and my old 14" barely clear - by less than 1cm.)
Did you know that all civic/integra/del sol rear disc's bolt up to all civics/del sols?
Did you know that Del Sol Vtec's have 1/2 length dual core radiators? (Its a good upgrade from the stock civic one... $100 at most auto parts stores.)
Did you know that changing your o2 sensor can improve mpg? (Do it right, get denso first-time-fit or oem)
Did you know that the 92-95 stock civic vx had an air diffuser for the rear bumper? (It really helps minimize drag.)
Did you know that you can calculate compression for a Bseries engine here: http://www.c-speedracing.com/howto/c...c/compcalc.php
Did you know that factory Del Sol seats were designed by Recaro?
Did you know that the b20a, in the older preludes, is the only Bseries that doesnt share the same parts as the other Bseries?
Did you know that JDM itr's have 36mm axles, instead of 32mm?
Did you know that 6th gen coupes and sedans have the same rear bumper, but all 96-98 and 99-00 are different?
Did you know that this thread was stupid, but we need to get this place going again?
What good 'Did you knows' do you have?
