Old 01-12-2002, 11:19 AM   #1
extasy
1990 dx
Here's the deal I have 90dx hatch...DPFI has air fuel,spark & compression, fires and idles fine, can free rev the piss out of it. Now in lies the question as soon as it is put in gear and under load it basically bogs to the point of almost stalling then it takes off. This occurs in every gear, had an injector code on the ecu so I pulled the fuse to clear it and see if it would return so far it hasn't, timing is within spec and compression is even across all 4 cyl. Any ideas are appreciated
Old 01-12-2002, 11:27 AM   #2
clogged injectors/fuel filter? i know you said it has fuel but, how do you know the injectors are working up to par? filter too?
Old 01-12-2002, 11:38 PM   #3
extasy
90 dx
the filter is good... the injector is the suspicious part though, when i pulled the plugs #2 & #3 were loaded with gas. I haven't had a chance to run a voltmeter over them to see if 1: they are getting proper voltage and 2: to see what the resistance is @ the terminals.. thanks.
Old 01-16-2002, 11:59 AM   #4
Badcar22
i highly agree
Old 02-13-2002, 04:21 PM   #5
2000Pimpinex
Super Moderator
2000Pimpinex's Avatar
I had this problem with my Probe. I had some kinda hole in my exhaust line. Everytime I put it into gear it would die. I can't remember exactly what it was.
2008 Mustang GT
1998 Hatchback SOLD
1985 Ford Bronco XLT 5.8 351W
w/ 33X12.5X15
