Old 09-08-2004, 08:21 PM   #1
With Hondata what do the stock injectors max out at power wise?
but still in the safe operating range that is.
Thanks!
Old 09-08-2004, 09:30 PM   #2
Well Hondata recommends a minimum of 400-440cc injectors on boosted D and B series. I'm assuming it all depends on the power curve. At 307 whp, my 550cc saturated was at about 70-80% duty cycle.
On stock 240cc injectors.... I can only guess around 230-250 whp. Later man....
Old 09-08-2004, 09:39 PM   #3
actually that brings up a question for me,
basically i can keep my stock injectors with low boost?
Old 09-09-2004, 10:57 AM   #4
so 175whp should be pretty safe then, thanks(again)!!!
Old 09-10-2004, 04:26 AM   #5
Nope. Not if you are boosted on Hondata. Run RC440cc at least.
The thing is, Hondata boost and n/a application tuning is a little different eventhough both still tunes A/F ratio for the most part.
There are Hondata tuners out there who will not tune your set-up with stock 240cc injectors tho......
