Old 08-18-2004, 09:46 PM   #1
Grip72
Grip72's Avatar
turbo kit comparison?!
i am currently looking at buying one of these 3 kits..what do you think is the best deal??
there are 3 turbo kits i am currently comparing.. here they are
KIT # 1
Kits come complete with the following:
Drag High flow 4 into 1 cast iron turbo exhaust manifold
Turbonetics T3/T4 High flow turbocharger assembly
Turbonetics Deltagate Mark II Wastegate (7 PSI Spring)
Drag High Flow front mount intercooler w/
polished cast aluminum end tanks
BLITZ Super Blow Off Valve
Drag mandrel bent high flow chrome plated intercooler pipes
Drag mandrel bent high flow exhaust down pipe
Drag wastegaste dump tube assembly
Drag Blue silicone hose and hose clamps
Drag High pressure/High volume inline fuel pump
Drag Boost dependent FMU fuel regulator
Intake air filter assembly
Map sensor bypass valves
Stainless steel braided oil feed line w/ fittings
Oil return assembly
All necessary hardware and fittings
All necessary hose and hose clamps
All necessary gaskets
Installation manual
1 year warranty on the parts included in the kit.
for apx $3461USD (includes shipping)
KIT#2
- Polished Turbonetics T3/T04E
- Drag High Flow Cast Iron Manifold
- Spearco Front-Mount Intercooler
- Turbonetics Delta gate Mark II Wastegate
- 2.5" Drag Downpipe w/ O2 Sensors Bung
- Drag Wastegate Dump Tube
- BLITZ Dual Drive Bypass Valve (BOV)
- Map Sensor Bypass Valves
- Vortech 12:1 Fuel Regulator
- Drag High Flow Intake System
- High Flow BOSCH Fuel Pump
- Steel Braided "Goodridge" Oil Feed Line
- High Temp, Heavy Duty Oil Return Lines
- All nessasary hardware and fittings
- All nessassary hose and hose clamps
- All nessassary gaskets
life time on manifold/1 year parts
FOR $3299.00 USD (shipping to canada extra)
KIT#3
- T3/T04B Turbonetics Turbo
- Thermocoated Cast-Steel Turbo Manifold
- Thermocoated Mandrel-Bent Downpipe
- Turbonetics Evolution 35mm Wastegate
- Spearco W.A.V.E Front-Mount Intercooler
- MF2 ERL 3D Map Injector Controller
- MSD Boost Timing Manager (BTM)
- 440cc Lucas Fuel Injectors (2)
- Turbonetics Raptor Blow Off Valve (BOV)
- 2 Bar Map Sensor
- K&N Air Filter
- (1) Case TS-1 Synthetic Turbo Oil
- Install Instructions & Wiring Diagrams
- All Necessary Hardware & Fittings
-1 year warrenty
for $3399.00USD (shipping to canada extra)
