Old 08-16-2004, 08:03 PM   #1
Jayberg00
Jayberg00's Avatar
Recomended Piston
i was thinking about putting some CTR piston in my B20 how well would it run and if its a good idea
Old 08-16-2004, 08:47 PM   #2
the b20 bore is 84mm and the ctr is 81mm
so you would need to have custom pistons made that match pct specs to fit the block
that would give 12:1 compression
Old 08-19-2004, 12:48 AM   #3
MissJDM
MissJDM's Avatar
Try forged JE Pistons. With CTR Pistons..10.8:1 on a n/a set up, I would rather get pistons with higher compression.
