Old 08-13-2004, 06:43 AM   #1
Jayberg00
Jayberg00's Avatar
RSX seats in 92-95 civic
does any one knows if the rsx seats can fit in the 5 gen civic coupe, or what would you have to do to make them fit
Old 08-13-2004, 08:34 AM   #2
change the rails
Old 08-17-2004, 08:36 AM   #3
Jayberg00
Jayberg00's Avatar
never mind guys i found it at http://www.rit.edu/~ltk6260/seats.html
i might do it how this guy did it.
!!!! oh also i saw a 99 SI at the junkyard with the spoiler on it, do you guys think the spoiler can fit my 93?!!
Old 08-17-2004, 08:53 AM   #4
what that guy did was kinda neat, but ghetto.
Old 08-17-2004, 09:39 AM   #5
and a lot more work than swapping the rails
Old 08-18-2004, 11:45 PM   #6
Do that and you'll be begging to die in an accident...
As far as I know ALL honda seats have the same pan just with different mount positions...
if the rails don't swap right over (like they do on LOTS of honda seats) then you can just swap out the seat pan from your seats onto the rsx frames... it's not as easy as swapping the rails or using crappy little metal tabs with ghetto holes drilled in them... but if you can't swap the rails it's the ONLY way I would consider doing it..
You can also use this pan swapping trick to make 4door seats fold all the way forward like 2 door seats do.. or to use s2000 seats in a car with a rear seat.
Old 08-20-2004, 09:58 AM   #7
Honda_Tengoku
i agree that is getto as hell. Why put in such nice seats with such a crappy install. it really negates the purpose.
