Old 08-12-2004, 10:51 PM   #1
racerface562
timing belts
when and how do should I know when to change my timing belt? Also, what should a good tune up consist of? Thanks
racerface562 is offline   Reply With Quote
Old 08-12-2004, 11:59 PM   #2
soundspeed
soundspeed's Avatar
Timing belt is done around 90-100k (kms) it's also a good idea to change your water pump at the same time. A good tune up should consist of plugs wires distributor cap and rotor. Also you may want to change your fuel filter depending on when it was last changed.
Old 08-13-2004, 12:19 AM   #3
racerface562
cool thanks. I ran into the valve adjustment thread too and I'll have to do that too. On another note....has any one used an o2 simulator? How good does it work, and is it a sure bet to help pass smog?
