Old 08-03-2004, 10:04 PM   #1
wheresmylicense
wheresmylicense's Avatar
O2 sensor in header...
going to be installing my OBX header soon, and i had a question on the o2 sensor that plugs into the manifold... what do i do with it? if i just unplug it, will it be ok?
thanks.
~DevT
Pictures of My Baby
Old 08-03-2004, 10:20 PM   #2
normally the header will have a bong welded for the o2 sensor. you might have to extend the wires for the sensor tho
Old 08-03-2004, 10:21 PM   #3
obx eh...I wouldnt be surprised if you lost power from it and it lasts only a few months. OBX anything is shit.
That o2 is your primary o2 sensor. Remove it from the stock manifold. DO NOT touch, mess with, clean, or tamper w/ the actual sensor element...be very careful with it.
When you change the header, put the o2 back into the obx's bung for it. Depending on your model, you may have to lengthen the o2 wires. You can do it yourself (i did) or you can buy an extension...somewhere...Im not at home and I cant look @ my favorites right now.
