Old 07-31-2004, 01:33 AM   #1
STL-A-KD-EX
Rounded Header Nut!!!! :(
How would you go about getting a rounded header Nut off? I have tried almost everything, and the Nut is messed up! I just want my header on :( oh yeah I cut my old Header off, should of left it on and took it too a shop! (live and learn hu) missed a car show in applevally cause I cant run with a open header now can you!!
Old 07-31-2004, 02:25 AM   #2
try craftman's stripped bolt/nut remover thing, its a set of sockets that have sharp edges to dig into the bolt/nut
Old 07-31-2004, 08:42 AM   #3
^try that and also heat the nut w/ a torch before trying to break it loose
Old 07-31-2004, 01:11 PM   #4
let me get this straight, you stipped the nuts that attach you header to the block, and then you decided to cut the actual header? WTF does that accomplish?? well anyway good luck getting it off. Other than that maybe try cutting the nut in half with a dremel tool.
Old 07-31-2004, 02:24 PM   #5
^(header to the head...not the block)
Old 08-01-2004, 12:52 AM   #6
STL-A-KD-EX
I got it off today, I cut the Stock header to get more access to the damn nut, but that did not work, then I was looking at it a little closer and there is a square hole to get a extension and a knuckle on and what not but that still did not work, but a big ass vice grip did, took almost 12 hrs though! Give me 30 min 2 extentsions a 10 12 and a 14 mm and some beer and I can get one on now!!! Whoo Ill get pics up soon looks key! Thanks Guys
