Go Back   HSTuners > Classified Ads > Vehicles For Sale
Old 07-18-2004, 11:33 PM   #1
slowasshatch
FS 94 Civic Hatch W/built GSR (racecar)
For Sale
1994 Civic DX Hatchback W/ Built JDM GSR motor
Engine dyno'ed 190whp and 136tq with mild tuning less than 4000 miles on motor
Engine
JDM 1.8 GSR longblock (papers!!)$$
Skunk 2 stage I cams $500
Type R retainers, springs, lost motion assemblies $250
Eagle H beam rods $350
Weisco custom ultralight forged 11.8:1 oversized pistons $500
Professionally balanced rotating assembly $200
Ported and polished GSR cylinder head (est 25 hours in polishing work) Skunk 2 intake manifold port matched and hand polished $200
BBK 70mm throttlebody port matched to IM $150
custom 3" intake to custom airbox $custom$$
Toda 4-2-1 header w/2.5 colletor (portmatched and hand polished as well) $900
Toda adjustable cam gears $150
Test Pipe $50
Apexi mid pipe $250
Type 1 axel back $100
type R oil pump $125
NGK plugs $12
MSD wires $75
Transmission
Jdm GSR transmission $1400
Quaife LSD (complete with lifetime warranty) $800
ATS 4.929 final drive $650
Brand new 3/4 gearset with syncro kit $250
Clutchnet 6puck sprung hub with HD pressure plate $250
Toda flywheel $400
Suspension
Tokico 5 way adjustable shocks $400
Ground Controll coilovers front 330lb rear 400lb $350
Type R rear sway bar 22mm (with beaks mounting kit) $150
SI front sway bar
J's racing upper C pillar bar $100
Neuspeed upper strut tower bar/ Benen lower tie bar $100
Energy suspension master kit $125
SRR spherical outer tie rod ends $80
Brakes
2000 Honda civic SI complete brakes, 40/40 prop valve, 15/16 mc $600
Power slot rotors all around $400
Hawk +p front pads $50
Braided stainless lines $100
Wheels
234x45x13 v700's on the lenso's (pictured)
Slightly used set of AE032r's mounted on wheels
Slightly used sey of Azenis mounted on wheels.
Misc
Skunk 2 extended wheel studs, with krouygen light weight nuts $120
JDMshit carbon fiber duckbill spoiler $200
Spoon shift knob $60
Apexi Vafc $200
Autometer Oil pressure, Water temp guages, and shift light $150
Split second A/F meter $50
GSR black leather seats with red stiching $300
Schroth 3 pt harnes's $150
JDM guage cluster $100
Fluidine alum. radiator $300
Walbro 190 liter per hour fuel pump/ B&M fuel pressure regulator and guage
Right know the car weighs in at about 2040, with a light weight battery, hood, and seats it could be in the upper 1900's.
There is a ton of other stuff that I am probabally forgetting, i put the prices next to most of the stuff just to give you and idea of what I have spent on her the last 2 years. Once I added it up there is about $14,000 invested in part's. That's NOT INCLUDING any of the sets of wheels that come with it, the hundereds of hours of labor that went into building it, or the car itself or the 1year old paint on it. Everyone that sees this car in person can appreciate the work put into it. No corners were sut along the way!
All of the work was done in our shop by me or by my boss and yes we are both ASE certified. This car does very well in SM here on the east coast of Fl. with the propper safety equipment I think that it could do well in the honda challange series.
The car comes just about all the misc extra stuff that I took out that you might want.
ASKING $12,000 OBO!!!!!!!!
email is key mattgast330@hotmail.com
VIN available upon request.
