Old 07-14-2004, 02:38 AM   #1
Jayberg00
Jayberg00's Avatar
B20 Vs B18
what the difference with the heads, what if i put a ls Head on the B20 block whats the out come what so good about that and what so bad about it
Old 07-14-2004, 11:10 AM   #2
heads are the same - same mold
ls cams are a little more aggressive
Old 07-14-2004, 01:56 PM   #3
Honda_Tengoku
B20 head has larger valves than the B18B head, and supposedly flows more.
Old 07-14-2004, 02:12 PM   #4
well I finally decided to look that up....youre right
33mm int valve and 84mm combustion chamber
Old 07-16-2004, 07:03 PM   #5
Honda_Tengoku
and produces better flow numbers! Its the intake manifold that is so restrictive on this engine, obviously designed for torque, efficiency, and throttle response.
