Old 07-13-2004, 12:26 AM   #1
lowering
Ok, a friend of mine says that i could lower my car with eibach lowering springs (1.5" drop) without having to do struts. Other people have told me otherwise. So can it be done?
Old 07-13-2004, 12:31 AM   #2
Kool-Aid
Well, I dunno...I have those eibach springs that you're describing and I did buy new struts (Koni Yellows)...my car rides great...but I don't know whether it's mandatory...it's recommended...but Im not sure if it's mandatory...
Old 07-13-2004, 12:59 AM   #3
a96710
a96710's Avatar
You don't have to change out the shocks right away. I had my Integra lowered on Skunk2 coilovers for almost a year without changing out the shocks. It just rides like ass and while you have it off it's easier to replace them at the same time.
Old 07-13-2004, 09:25 AM   #4
soundspeed
soundspeed's Avatar
I dropped mine with the eibachs and tokico shocks and the car rides awesome. But you should think about going with the sportline, it's a 1.8 drop. That's what I have with 17's and they don't rub and there is still a little bit of a gap between the tire and wheel well. You may not even notice a 1.5 drop.
Old 07-13-2004, 02:14 PM   #5
Kool-Aid
It's probably just recommended that you do both the springs and struts but it's not necessary...
Old 07-13-2004, 05:26 PM   #6
Honda_Tengoku
Eibach pro-kits are designed to work with factory shocks. They are 1.5". At 1.5" Its not so much the amount of drop u have to worry about its the spring rates. Go with the Skunk2 coilovers on and u will be a bouncing motha fu$#%$!! Way too much spring rate for stock shocks.
