Old 06-29-2004, 09:14 PM   #1
Jayberg00
Jayberg00's Avatar
B20
B20 in hatch but wont start what am i to check what could br the problem
Old 06-29-2004, 09:43 PM   #2
air fuel spark?
Old 06-29-2004, 10:52 PM   #3
that'd be a good place to start... but with a swap it's generally not as straight forward as that... it could be a million things...
After you check for fuel and spark I'd start trying to check codes and see where you can go from there
Old 06-29-2004, 11:17 PM   #4
does it crank at all?
Old 07-01-2004, 08:24 AM   #5
Jayberg00
Jayberg00's Avatar
the motor turns over but it wont fire, i checked every thing. this is the set up b20b4 motor, 93 ls intake mani, 93 distributor, 93 ex wire harness. do you guys think it could be the distributor?
Old 07-01-2004, 04:34 PM   #6
did you do the conversion for the dist? Its wired correctly - obd1 dist -> obd2 motor?
Did you put the right plug wires in the right places?
