Old 06-06-2004, 01:44 AM   #1
El-Draper
Turbo 94 Honda Civic ?! PLEAS HELP
Hey guys,
I have a problem. i recently just put a turbo on my 94 4 door civic with a d15b7 motor. The kit includes a td05h turbocharger, front mount intercooler, greddy bov, vortec 10:1 fmu, check valves and assorted pipes and hardwear.
When i drive my car it is shooting oil out of the bov when i change gears, and blowing really thick grey smoke out the exhaust, also the oil quickly depletes after i drive.
what is going on and how will i go about to fix this problem?
Old 06-06-2004, 04:04 AM   #2
i'm guessing somekind of seal is bad in the turbo
Old 06-06-2004, 08:39 AM   #3
El-Draper
Is it safe to run my car on standard internals? at around 7psi?
do i need a decompression gasket or forgies or a piggy back computer etc etc...?
Old 06-06-2004, 11:00 AM   #4
There are 2 things that may cause this:
1) Your turbo shaft seal has failed causing oil to leak by on both side of the turbo assembly (compressor and turbine), thus sending oil to both the exhaust and intake.
2) Fried piston rings and/or blow-by will allow oil to get into the breather tube/PCV causing oil to get sucked into the compressor and back into the charged pipe.
Your intercooler is mostlikely full of oil as well. Lowering the boost will not solve the problem, although it may minimize it. Start with the basic. Inspect if your oil return line is pinched. If it is, then fix that right away. This will minimize oil from passing through the turbo shaft seal which may be the probable cause of the problem. FMU's will still do it's thing regardless of what the boost setting it. If you ever get this problem fixed, get a "real" management system like Hondata or AEM EMS. Even the GReddy E-manage is starting to come around. Fuk FMU man...... it's not healthy for your boosted ride.
Goodluck
Old 06-06-2004, 05:50 PM   #5
El-Draper
how much are thosepiggy back e-management systems?
and where can i pick one up?, also is it possible to tune the standard ecu?
Old 06-06-2004, 10:34 PM   #6
NAPALMsunrise
the n00b in me wants to know what these are suppose to mean ( d15b7 ) and (td05h) from the original post that started this thread.... are these manufacturer numbers or something HAHA g0d i feel s0 n00b like but im getting use to it
Old 06-06-2004, 10:45 PM   #7
d15b7 is engine code for usdm non-vtec eg's (civics 92-95 - 5th gen)
td05h is a turbo size
I suggest you familiarize yourself w/ some codes...
http://www.hondaswap.com/forums/inde...howtopic=29825
http://www.hondaswap.com/forums/inde...howtopic=31989
http://www.hondaswap.com/forums/index.php?showforum=33
Old 06-07-2004, 04:48 AM   #8
El-Draper
Would my motor be fine running 7psi, with standard internals
and a 255l/hr hp fuel pump and the vortech 10:1 fmu.
If not who makes piggy back computers, where can i get them from and how much aproximately do they cost?
can piggy back computers be tuned so you motor will runn better
cheers guys
get back to me with some advice.
If any one has aol my name is lylehondapower
and my msn messenger addy is Ldraper_85@hotmail.com
Old 06-07-2004, 09:20 AM   #9
That depends. Have you done a leak down and compression test on the motor?
The stock pump is probably more than enough for that kind of boost.
(I wouldnt use the fmu) Have you looked into running the afc hack?
( http://www.geocities.com/thermalfid16/VAFChack1.html )
It uses a piggyback afc and larger injectors - lots of people have success w/ it.
You could get a used afc as low as $130...or spend over $300 for a new one (depending on where you shop).
(The ones made by Apex'i come in either a standard unit(safc) or one that controls the vtec point(vafc)...both have different features)
Old 06-07-2004, 09:53 PM   #10
NAPALMsunrise
thanks for the codes links/// Ill check em out and familiarize myself a little... thats what im here for HEHE thanks again
Old 06-07-2004, 10:33 PM   #11
255 LPH and 10:1 FMU is actually a bit too much on low boost. Since you are in Australia, I'll hook you up with other management similar, if not, better than Hondata. Email my friend predator at neokeo@hotmail.com and tell him I gave you his email addy... he knows me by "thermal" . He works on all kinds of turboed Hondas over there in Australia. He should be an authorized dealer of Autronics stand alone systems which is simialr to AEM EMS. He also tunes it... Goodluck.
Old 06-08-2004, 03:51 AM   #12
wal
wal's Avatar
is a d15b7 engine a good one to turbo? as i have one ma self but was thinkin b16a2 swap then turbo. does anyone know how much power is possible outta this engine ?? with just like a turbo and a few other bits and pieces
wal is offline   Reply With Quote
Old 06-08-2004, 05:32 AM   #13
El-Draper
does neokeo@hotmail.com use msn messenger or aol?
where abouts in ozzy is he?
Old 06-08-2004, 05:37 AM   #14
swap to a different engine, theres not enough aftermarket support for the 1.5. your cheapest swap would be a d16z6, then look for a b16 or b18a/b
Old 06-08-2004, 06:11 AM   #15
El-Draper
Hey thermal,
are you on aol much or do you use msn messenger?
Old 06-08-2004, 10:33 PM   #16
Originally posted by El-Draper
Hey thermal,
I'm barely on AIM man..... check with me on the weekends tho..
Old 06-11-2004, 06:41 AM   #17
El-Draper
what is a good computer system to run with a turbo civic?
one the is good value and not too expensive
also if i have a setup for a td05H 16 g turbo, would i be able to change it to a td05 12 g easily with out changeing any flanges or pipe setups?
Old 06-11-2004, 07:36 AM   #18
Nothing less than a Hondata is what I recommend. The AFC "hack" is okay but the tunability is not even close to what Hondata can do.
As far as the interchangability of the turbos, both turbos utilizes different turbine flange.... so that means it will not just slap on.... I wish it is that simple. Piping wise will be minimum to nothing cuz the physical size of both turbos are not too different....
Old 06-11-2004, 08:07 AM   #19
cashizslick
or, get a B16. . . . . .
Az - how much nawz u gonna spray on ur D16? If ur not going over a 75 shot (ever) then why get the direct port kit when the NX shark nozzle deal is just as good for a low shot application?
- just asking because i am getting the NX wet kit (w/shark nozzle) as soon as i get some money together and get a Walbro 255lph fuel pump. . . . i guess you could say i wanna hear your take on this?
Old 06-11-2004, 09:04 AM   #20
El-Draper
how much can you get those afc hacks for?
what things should i do to my motor to insure that it does not detonate
Old 06-11-2004, 11:24 AM   #21
what things should i do to my motor to insure that it does not detonate?
Get it tuned on a dyno
